I used to deliver tires to a little tire shop on main drag in Cave Springs AR years back. Nice little town. Nice folks around there.Yes sir , Fayettville Arkansas, the jeep is in cave springs 30 minutes away
Gotta work to get my money to support my expensive habit . Besides after we figured out we couldn’t fix the suspension Sunday without ordering some parts ( which by the was all I was asking about to start with ) we installed a snorkel on my busted up LJIf we keep talking at it, we might convince it to fix itself because god knows ain't nothing else gonna work.
Cause I am a poserWhy?
Lol. That is the best answer ever for a snorkel.Cause I am a poser
I feel like a poser every time I look at the one the PO installed on my Jeep lol!Cause I am a poser
Thank you fSo for the springs to keep them from rotating on the perches try these;
https://www.northridge4x4.com/part/1100108-clayton-stainless-steel-front-spring-retainers
For sway bar mounts you can’t do better than these;
https://www.shop.blackmagicbrakes.com/Raised-Swaybar-Link-Mounts_c40.htm
As for the Control Arms these should suffice,
https://www.core4x4.com/product/t1-j-tjljzjxjmj-fs4/
Thank you for being the only person to answer me on all of my questionsSo for the springs to keep them from rotating on the perches try these;
That’s hilarious and accurate !!! LolJust reading through this - am I correct that the the jeep is literally self destructing so a snorkel was installed-
Just askin’
Axle or frame side?Thank you f
It is greatly appreciated ! May I ask you one more ? For the upper control arm mount on the passenger side do you have a recommendation ?
I’ve done worse.That’s hilarious and accurate !!! Lol
I did a similar mount and joint and it really made a difference. The stock mount is pretty thin- works but is basically heavy sheet metal.
This one that the broken control arm is still hooked to . Thanks, KurtAxle or frame side?
No sir but I will get one@Keg do you have photos of your full shock, print and bumpstop setup? It might help people identify if something is missing or not set up right.
