Sway bar mounts on both sides and upper control arm mount are toast
Yes sir , Fayettville Arkansas, the jeep is in cave springs 30 minutes away
I used to deliver tires to a little tire shop on main drag in Cave Springs AR years back. Nice little town. Nice folks around there.
Reactions: Keg
If we keep talking at it, we might convince it to fix itself because god knows ain't nothing else gonna work.
Gotta work to get my money to support my expensive habit . Besides after we figured out we couldn’t fix the suspension Sunday without ordering some parts ( which by the was all I was asking about to start with ) we installed a snorkel on my busted up LJ 😂
  • Face Palm
  • Wow
Reactions: JMT and John Cooper
So for the springs to keep them from rotating on the perches try these;
https://www.northridge4x4.com/part/1100108-clayton-stainless-steel-front-spring-retainers
For sway bar mounts you can’t do better than these;
https://www.shop.blackmagicbrakes.com/Raised-Swaybar-Link-Mounts_c40.htm
As for the Control Arms these should suffice,
https://www.core4x4.com/product/t1-j-tjljzjxjmj-fs4/
Thank you f
Thank you for being the only person to answer me on all of my questions 👍 😊
It is greatly appreciated ! May I ask you one more ? For the upper control arm mount on the passenger side do you have a recommendation ?
Thank you f
Axle or frame side?
Everyone here is willing to help in anyway possible. Recommended replacement parts are one thing. However if we don’t know what caused the damage and components to fail then we are just setting ourselves up for another failure. That is why most were asking more questions and for more pictures. To try to grasp The Whole situation of how/what led to the carnage. It wasn’t until today that you stated the sway bar mounts had been broken for a while before the arm. That changes things from the first post.
It isn’t common to break the sway bar link mounts. So if we just suggest the parts and you fix it and it fails again then we must have suggested crappy parts. Being the damage is so odd we need to find out what caused it to really fix the issue.
