Are these bolts supposed to be unevenly seated ?
connor grimes
Los Angeles
In the middle of replacing my valve cover gasket and noticed these bolts with square heads are not all uniformly seated , it appears to alternate between the four bolts
Yes and you need the special height gauge you set on both sides that straddle the rocker arms and gives you an exact dimension down to the top of each one. If you let them get that far out of adjustment, you will cause catastrophic damage.
