Hey All,
Took the TJ I just bought to the shop to fix a coolant leak. While diagnosing the leak, they detected hydrocarbons in the cooling system with their machine, which they say indicates a blown head gasket or other significant head, valve, and/or block leak. Incidentally, the seller didn't provide a valid smog certificate when they sold me the car, which they're required to do in California.
Regardless of if the vehicle will pass smog, should I try to void and undo the sale on the basis of the missing smog certificate? I don't want to be stuck with significant, expensive and unexpected engine problems.
Some additional info:
This is my first TJ and I'm a very much a beginner; I want to learn more but wondering if I got more than I bargained for with this specific one.
Thanks!
- Vehicle is a 2000 Wrangler Sport 4.0L w/ auto transmission and 160K miles
- PPI showed leaky oil pan, rear main seal & valve cover as well as empty coolant reservoir and radiator, and the AC/heat blower only works on speed 3. The seller told me about all of these beforehand.
- I learned these oil leaks on are common w/ TJs so I wasn't too concerned about those
- Seller said the coolant leak didn't really bother him he just kept adding more coolant every few months
- PPI didn't specifically check for a blown head gasket because they didn't see any other signs of it: no exhaust smoke, oil looked good, no engine codes. I assumed the coolant leak was just the radiator or hose or water pump or something and decided to move forward and buy it.
Thanks!
