iamloganjames
likely not. you'd lose too much pressure at the radiator. But, you could disconnect both rad hoses and pressurize the top one with the bottom one plugged. Should be able to pull and hold a vacuum that way.Would a pressure test with a cracked radiator expose this head/gasket leak?
