G Gsalas422 New Member Joined Jan 22, 2022 Messages 2 Location Nm Jan 22, 2022 #1 Anybody had this issue I replaced with struts from amazon im not sure what the problem is...it also seems as if the new struts have too much pressure
AndyG Because some other guys are perverts Lifetime Supporting Member Joined Jul 30, 2018 Messages 15,994 Location Alabama Jan 22, 2022 #2 Are you missing the clips that keep them captive on the ball-
OP G Gsalas422 New Member Joined Jan 22, 2022 Messages 2 Location Nm Jan 22, 2022 #3 No the clips are in it...it seems like the struts I purchased are too strong or require too much pressure to allow the window to close
AndyG Because some other guys are perverts Lifetime Supporting Member Joined Jul 30, 2018 Messages 15,994 Location Alabama Jan 22, 2022 #4 Gsalas422 said: No the clips are in it...it seems like the struts I purchased are too strong or require too much pressure to allow the window to close Click to expand... That is a pain- hopefully someone can chime in with the brand they’ve had success with. Any hardtop owners out there with ideas??
JKP TJ Addict Joined Aug 20, 2020 Messages 1,529 Location Warner Robins GA Jan 22, 2022 #5 Probably a "one size fits all" strut. The correct ones are matched to the weight of the hood, hatch, etc. Not something you want to stress too much or you'll be buying the glass as well. Reactions: AndyG
JMT Just another auto… Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 22,330 Location 🌎 Jan 22, 2022 #6 Gsalas422 said: No the clips are in it...it seems like the struts I purchased are too strong or require too much pressure to allow the window to close Click to expand... I’ve replaced struts but never had that issue. Can you post some pictures of what’s going on? It sounds like if/when you get it shut it just opens again. Is that right?
