“Thought it was done” build / blog
Today we tackled getting the fasteners countersunk. I could not use the existing slot holes that the skid came with due to how oversized they were. So with some Wizardly advice I decided to drill new holes and install new nutserts in the frame. This allowed me to countersink the bolts.
KEWL
Glad you got it figured out
Talk about thinking outside the box. So simple yet I never would have thought of that as a solution.
I think this is because most folks find replacing a frame nutsert intimidating. The reality is it's surprisingly simple!
Clearly they haven't installed sliders and corners if a nutsert seems scary lol.
Reactions: Wildman and Irun
I'm about to do gears for the first time in almost 20 years. I'll admit that one has me pensive. I will either go well, or I'll be buying new gears and doing it again! ;)
Reactions: Alex01
Just take your time and be patient. I'm going on 4 days of working on mine and will have at least one more day if not two before their done. When I was doing all the time I could know out a gear install in 4-6 hours per axle.
It's been over 12 years for me so yes I do know how you feel.
Reactions: DETOUR and Irun
Good news is I will be in no hurry and the axle is out. That alone makes it much easier!
If my gears fail or I swap to an arb down the line I'm going to attempt gearing next time. Looks like a fun thing to learn and downtime doesn't matter to me. Looking forward to following your installation.
Reactions: DrDmoney and Irun
I'm happy about the fact that the HP30 doesn't use a crush sleeve like the LP30. That makes things a little easier for me!
Reactions: Alex01 and Wildman
I was a bit intimidated when the idea was proposed. But after a couple minutes I realized it was a fairly simple solution. Under the frame rails and sliders is where we tend to pass large rocks so the smoother the better was the philosophy.
I think I'll need to copy that. I'm still thinking I'll swap to the ultra low skid one day though so I'm not in a rush.
In todays world of forums it is easier than ever to tackle things we aren’t sure of. It has never been easier to find information.
Agreed. There has been a lot of things I most likely wouldn't have attempted other than from others coaching me thru the process. Just cross my fingers I've done it correctly.
Yes I wish I would have built a crossmember mount and a separate skid. But I can’t imagine pushing my tcase up higher as my DS angle is 21 degrees now.
It had the dreaded harmonic drumming vibration at 60+ mph. So I first checked pinion angles. The rear pinion angle was out by 7. Thought that would be it, nope. Adjusted to within approx 1. Felt vibrations lessened, but harmonic remained. So I removed rear then front and drove without each. Problem went away when front was removed. I found the front was out by a lot. Adjusted pinion up until vibe stopped. It is within 2* of DS angle. Still have a slight vibration above 65, but not a harmonic pulsing mind numbing vibration.
That’s when I discovered the whole track bar interference and read how to properly set bump stops. Had the front set pretty close.
While fighting a stiff steering issue, the term “scrub radius” was explained to me. Due to haveing 3.75 back spaces wheels and 1-1/4 wheel spacers my scrub radius was very excessive. I removed the spacers and now I can turn with my locket engaged. So at this point I decided it was a good time to revised my front bump stops due to tires being moved in. So I rechecked my front and have it set. Once I raise my front upper shock mounts 1” I will be using 100% of my rancho 999255 fronts.
Gollywomper
Sorry, I just can’t resist, but what the heck are you looking for north of 65+ mph with your rig ?
Please don’t take any offence
Take care
~•lllllll•~👋🏿
Reactions: Gollywomper
