Toughness personified
Yes, (1) CE-9701TRL and (1) CE-9701TRR
I posted this over in @jjvw's thread - but for those that don't already have a correctlync and want this, you can just buy the individual pieces. I believe this list to be complete:
* CorrectLync Drag Link $358: https://www.rockjock4x4.com/CE-9701DL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Drag-Link-Complete
* Steering Damper bracket $43: https://www.rockjock4x4.com/Steering-Stabilizer-Shock-Bracket-Kit-fits-1-1-4-Inch-Tie-Rod (thanks @JDM)
* BMB Tie Rod $185: https://www.shop.blackmagicbrakes.com/4340-TIE-ROD-HEAT-TREATED-4340-TIE-ROD.htm
* Currie TRE RH $82: https://www.rockjock4x4.com/CE-9701TRR-TJ-LJ-XJ-MJ-Currectlync-Tie-Rod-End-RH
* Currie TRE LH $82: https://www.rockjock4x4.com/CE-9701TRL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Tie-Rod-End-LH
Puts you at $750 + tax and shipping all in.
https://wranglertjforum.com/threads/daily-driver-go-where-i-want-to-build.9410/page-201#post-1047541
Puts you at $707 + tax and shipping all in.
Or if you wanna save a few bucks on a "gently used" Currie tie rod Instead, hang out here for a couple weeks. I'm sensing a few of us will be looking to sell ours when the upgrades start arriving.
Reactions: rasband
Effectively, you'll just be selling the tie rod sleeve and keeping the drag link and Currie tie rod ends, correct? Would the Currie tie rod sleeve be a huge improvement over the factory one? Or, the ZJ tie rod? I'm genuinely asking. Not trying to be a dingus. My guess is the Currie sleeve would be a definite strength improvement both ways.
Reactions: SvtLdr
Reactions: rasband and SvtLdr
Yes, correct just the Currie tie rod, not the ends.
Yes, big improvement in strength. Especially when combined with the tie rod ends.
Reactions: bobthetj03
Sorry rasband . I tried to quote part of your post and messed it up .
And just to confirm, the drag link is not required either is it? This can be done with just the upgraded tie rod, no?
“Puts you at $707 + tax and shipping all in.”
Most people would probably also need a new steering stabilizer bracket for the larger 1-1/4” tie rod
https://www.rockjock4x4.com/Steering-Stabilizer-Shock-Bracket-Kit-fits-1-1-4-Inch-Tie-Rod- $43
That was enough to convince me to order the complete Currectlync in addition to the the tie rod from BMB .
Thank you! I didn't notice that. I added it. It sure isn't cheap if you go all new, especially through Currie/RockJock. The full setup is cheaper elsewhere, or best yet - used.
Reactions: SvtLdr and JDM
I never tried on my ZJ setup, but since the TREs fit the knuckle without changes my guess is yes - they should fit the factory drag link. I never took a picture of them side by side, but the ZJ was a big improvement due to being solid - the Currie (and BMB) tie rod is both solid and larger (I think by 1/4" diameter).
Reactions: SvtLdr
The Currie/RockJock and BMB tie rod and C/RJ drag link are 1.25".
Reactions: SvtLdr
I concur with the list above. In fact, my box from RockJock4x4 showed up today!
Reactions: rasband
Considering the “$750 all in” plus shipping and tax , I found it better for me to get the Full Currectlync on Amazon for $580 with free shipping and ordered the heat treated tie rod from BMB for $185 plus shipping . That gives me a Rock Jock Currectlync tie rod for free . Even though I’ll probably never use it . Maybe I’ll just sell it ???
Keep the BMB tie rod in the box with the hope of "collector item status" some day.
Kind of what I am thinking. I haven’t bent this bar yet. I only got a couple of trips on the Currie steering setup. But my lips are kind of chapped. Some chapstick would be nice!
Yeah, that's how many of us justify the next purchase from The Wizard. Well, I'm all out of chapstick, so...
