I was going to replace my steering gearbox for excessive play and a very large dead center and ran into an issue with the hose connections.
The OEM box has double flare fittings with an o-ring, the remanufactured Byautoparts box has single flare fittings with a brass insert.
I crossed referenced the part numbers and Byautoparts states it should be a direct replacement.
I'll call these knuckleheads Monday, but in the meantime wondering if you all can help.
Do I have the wrong hoses, the wrong steering gearbox, or both?
