Good. So you aren't willfully and arrogantly ignorant.I’m messing with him. He knows it.
Dude we’ve had this conversation before. It’s a bit of fun. I get a kick out of teasing anti social people. It’s a illness I have.Good. So you aren't willfully and arrogantly ignorant.
Whatever the hell its called on steel... (!!)Doesn't matter where it is anodized, if it isn't UV stabile black, it will not hold up.
Why are you using aluminum bolts?
i'll take a stab "cadmium plating"??if it's black, "oxide"?Whatever the hell its called on steel... (!!)
My first synthetic was a cheap one off Amazon, might be the same brand even. It did fine for while I ran it and the only reason I stopped was because I wanted to run a safety thimble and when I cut the line it wasn't a cable I could do a bury splice in. It was just a sheath on a dyneema-ish rope that when compared to what I replaced it with felt vastly different.So found a Warn 9.5xp this weekend, yes bought it!!...has the original steel cable, but also came with a new synthetic rope. anyone have any experience with this item? I know the go-to is the TRE setup with thimble, but thats just shy of $300... this is brand new in the box...and in hand..is the one I have worth loading up or no? This is the only thing I could find on it...
https://www.ebay.com/itm/ORCISH-Syn...d=link&campid=5337789113&toolid=20001&mkevt=1
Here's the one I mentioned opened up.People talk allot about brands, it's all very similar. Don't think any off road vendor sells anything but Chinese crap. Castro Bargains sells dyneema, SK-75 for a good price on ebay. I'm no fan of these off road vendors marking up the price of Chinese crap. What does good or bad UHMWPE feel like? I guess you have to break some to know.
The wire cable thats on it hasn't even been unspooled yet...so really im thinking of keeping that on there... while getting the funds prioritized for the TRE system vs taking new wire cable off and putting on an interim... I think it may be a good idea to check out and lubricate the wire...its been sitting for awhile...go from there...My first synthetic was a cheap one off Amazon, might be the same brand even. It did fine for while I ran it and the only reason I stopped was because I wanted to run a safety thimble and when I cut the line it wasn't a cable I could do a bury splice in. It was just a sheath on a dyneema-ish rope that when compared to what I replaced it with felt vastly different.
So it's likely fine for a while but I would recommend planning on an upgrade eventually though to a reputable brand.
If the wire cable is unused make sure you fully unspool and reel it back in under load to get tight wraps on the drum.The wire cable thats on it hasn't even been unspooled yet...so really im thinking of keeping that on there... while getting the funds prioritized for the TRE system vs taking new wire cable off and putting on an interim... I think it may be a good idea to check out and lubricate the wire...its been sitting for awhile...go from there...
That's a nice find!So found a Warn 9.5xp this weekend, yes bought it!!
Roger, got it....Was going to have the thimble pre-installed with the thimble from TRE when I do...@mastergunnera8
This double-braid style dyneema has had several failures in marine use and industry has moved away from it. Single-braid just looks like the inner part of this photo. Double braid makes it impossible to inspect for damage and it's more expensive, and is much harder to splice.
I was going to bother you...lol...Im thinking of running out to Peters Mills soon for the maiden dirt trip...I'm with @Gollywomper. Pull the cable and run what you have until you can save for better rope. Unless you plan on doing some extremely hard pulls, it will be fine. Plus, this will give you a practice run at spooling rope. You can always text me and I'll be happy to lend a hand!
