YesQuick question: 2x4,s flat or on edge, 6x2,s flat or on edge?
cheers
cheers
The Crack?!!Success. After 3 days of applying PB Blaster and a little arm wrestling I got the 6 main body bolts out. No pics unless you want to see rusty bolts. Once I have the lift in I'll post a pic of the 'crack'.
Sooooo would you say the squeak has been 'Erased' then ?I fixed a very annoying squeak in the dashboard. I found that the squeak stopped when I reached up & jammed my fingers in the gap above the speedometer/tach enclosure so I tried jamming different things like rubber or plastic tubing into the gap & they all worked for awhile until they either compressed or popped completely out. Today I bought some pink gum erasers that I found in the office supplies department at Wal Mart. I cut them down so that they would fit onto the gap very tightly & now the squeak is GONE! I put 4 of these eraser pieces into the gap & I think it’s going to be a permanent fix. I might color them black with a magic marker or something, but they really don’t show because the Jeep is lifted & you would need to be on a step ladder to see the gap.
Yes. You could say that.Sooooo would you say the squeak has been 'Erased' then ?
Yes said the woman, 4" 6" or 10" Rise doesn't matter to me as long as its 6" round!
I used 3/32" Neoprene Spring Rubber Sheeting (70A Durometer) from McMaster-Carr when I had my TNT fenders. I cut the sheeting to shape and fit then I drilled holes in the fender and used the push-in body panel clips to hold it in place.Anyone know of any metal wheel well inserts for the TJ? I have aftermarket fenders on that are open and nothing to protect the engine bay from water and mud.
Over the weekend I explored the Huron National Forest, discovered the wonders of a front(lunchbox) locker, tore off one of my fog lights and “disconnected “ the other, discovered the wonders of discos and did some extensive pinstriping
I know the feeling this year is gonna break the bank on mine lolThis thing is going to nikel and dome me to death
JustEmptyEeveryPocketGot the new trans cooler lines installed and now it's keeping its vital fluids on the inside
Also found the A/C leak so new condenser is on the way
Huron National ForestWhere is this? Looks right up my alley, we live over towards Bay City
