Did the stock spring "bow" at all? How much of the frame was replaced and who did it? Did they "cap" your original frame, or did they cut out and replace sections?
As the suspension droops, the axle will move back and can cause that bow. If your trackbar is connected, you have more bind on the passenger side and the driver's will droop lower. I would like to see you put the wheels back on and lower it down on its own weight. Then take a picture from the driver's side and the front. Try to get the whole front end, vs just the spring.
lets see some other angles... im interested in how your track bar is affecting this. some photos from the front would. be good. is the driver coil also bending in under the frame?
if you disconnect track bar and steering does the problem go away?
you can put weight on it without the steering or track bar hooked up, there is enough triangulation in the arms to keep it from doing anything too stupid.
Your control arms look stock from what i can see.
Is it still bowed? It looks like your axle is shifted quite a bit to the passenger side.
But if those are the safety caps repair sections that they look like he won’t have the frame holes called out to reference to..
You know I hope it’s that but I have the pigtail situated firmly into the slot at the bottom so I’m not sure how I’d situate it any differently unfortunatelyAfter going back and looking at your pictures again it doesn’t look like you have the drivers seated correctly at the top. Not sure if this would cause that much of a bow, but it is something.
Jack it up and shift the top of the coil towards the rear. There may even be an indent in the isolator where the factory coil was seated and your spring just isn’t going into it. The factory coils were a different length so the top tail may have been in a different location. If that’s the case just rotate the isolator so it matches.
But then the lower pigtail won’t be in the slot if I do that
No you can rotate the isolator on the top, that rubber piece that the spring sits against is just slid on over the post. But that spring definitely looks too far forward as well.
he's a novel idea. put it all back together and put it on an alignment rack.
