Installed a new liftgate glass retainer from the Crown kit (55175042K).
Went to put on the weatherstrip but there’s a gap like the weatherstrip is too narrow. Old one fit tight in the new retainer.
Anyone know if it’s supposed to fit that way?
I *love* the rear-set garage! That's the way it should be done!
If it is short side to side, remove the first few inches of the double sided tape backing from each end, leave the tails hanging out the bottom. Stick one end then stretch the weather strip and stick the other end.
Pull the tape backing. I also used some 3m weather strip adhesive on the ends. And adjusted the glass for as good of a seal as I could get, still small holes of light in the bottom corners but much improved from what it was.
Started on the Dana 30/35 to 44 axle swap project. Never done this before, so I was a bit slow removing the old one. Just figuring out what needed to be removed and all that good stuff. The only real hard part was probably getting the old parking brake lines out of the bracket.
I’m not exactly rushing this project. I plan to stuff the Dana 44 in tomorrow morning when my brother-in-law can give me a second set of hands.
I may not even start on the front axle until next weekend. Or I’ll do it throughout the week after work little by little. It’s nice having another Jeep and another car I can use. So the TJ can sit here as in progress for as long as needed.
Still need to pick up another locker pump. And some miscellaneous airlines, connectors, etc... Probably replace the disc brake rotors & pads too on the new axles.
That looks great,too bad the mrtr 35s are discontinued
44 swap is easy,make sure everything is new in the brakes!
