I recently decided to build my own version of THOR's cowl intake system with a 30 dollar autozone filter and some elbow grease, saving me about 170$! I noticed though now since the jeep is taking in much cooler air, i am getting a high voltage reading from the number 1 intake air temp sensor. I wanted to ask if anyone has been able to clear the check engine light after doing such a cold air intake. I understand that the jeep is probably running lean now. I looked at THOR's install instructions and they seem to completely gloss over this error code from your air intake temp sensor as being an issue. My setup is almost identical to THOR's intake system so I'm wondering how others may have dealt with the code, if anyone could chime in. Also I've attached pictures for better explanation and so if anyone would want to build a true cheap cold air intake for themselves, you can reference mine. I would highly recommend it, I noticed increased throttle response instantly and for 30$ i think it's a no brainer, plus it sounds cool!
