Well here's a teaser pic. My rollers didn't quite bolt up to the base, gonna have to fix those, but shouldn't be too hard. Took me a few hours, but the toe jack worked flawlessly and I was able to get the whole thing 9.5" up off the ground.
This is a Weigel camelback drill press, I think it's their 21" model. It's unlike any other camel back I've seen before, they put a lot more effort into the castings up at the top and it's comes with all the bells and whistles that are hard to find on others. So far I've found one old forum post about Weigel and a few copies of old brochures. Unlike the brochures though, this one has a 5MT spindle taper whereas they list it coming with a 4MT. I don't think it's been modified too much, and everything seems to be complete and not broken.
Camelbacks have a ton of rotating inertia and gobs of torque. The motor on this one is rather small at just 1.5hp, but it has 6 spindle speeds ranging from 400 all the way down to 15rpm. It is also supposed to have some type of clutch assembly built in for power tapping purposes to prevent broken taps.
It also has an elevating table as well as a sliding quill support on the vertical dovetails. Rough measurements show that I should have around 2 ish feet of quill travel I think. Though I've never run one of these before, so it'll be a learning experience.
It also has gear driven power down feed. To give you an idea of what this drill can do, when I'm running CNC machines at work for example I would run a 1/2" drill in steel at .001"/rev of feed for every .0625" of drill diameter, so .008" per rev for a 1/2" drill.
The highest power down feed rate on this drill is .043"/rev, which is absolutely insane. I've never even topped .020" with the fancy tools and equipment at work, don't know if I'll ever have the balls to test that out. .043"/rev would be about the right feed for what I would run a 2.6875" diameter drill at.
I'm very excited to bring this thing to the shop, though the only problem I haven't figured out yet is how to get it through the garage door. On my rollers it's about 8ft tall, and my garage door is a little under 7ft. Current plan is to pick it up next week, take it to a friend's shop to disassemble, move, and reassemble in my shop.
If anyone has any ideas on how to safely tip it over a bit I'd love to hear them. It's probably right around 1500-2000lbs.
View attachment 321373View attachment 321374
