One more detail in preparation for several days of wheeling. Added a Nth Degree skid to the rear differential.
Does the protection out way the loss of clearance?
I feel your pain.
I notice you've got the sway bar end links attached differently on each side. Was that intentional? Do you have any interference with the lower mounts and the wheels such as this? https://wranglertjforum.com/threads/sstjs-mostly-stock-97-se-2-5.50320/#post-886164
That's the beauty of this particular diff skid. There is no loss of clearance. The way it's designed, it tucks up just above the bottom of the diff housing. It's primary purpose is to protect the rear yoke, which I've broken a couple times without the skid. Unfortunately, the skid is no longer made.
I have the TR ends for #2. Now, I'm searching for #1 and #3. If I can find those, then I'll order Blaine's TR.Yep, that is the inherent weak spot for that ZJ tie rod. Bent mine almost in the same spot on the Rubicon trail. I have BMB goodness waiting in the wings.
The tie-rod flip is another great mod to move that sucker farther out of harm’s way, albeit it does require another mod to move the sway bar links. Me whiskey eye sees a bent shock shaft but it could just be the whiskey.As I've said a couple times, the Jeep, overall, exceeded my expectations. I went everywhere the group on bigger tires did, and a few places only a smaller contingent ventured into. Although I didn't have anything I'd classify as "major" carnage, there was some damage. Those things included the following:
1. Took out the driver side mirror - this was on a very steep off-camber hill climb, where only 3 of us went. I was the second up and after watching the first person struggle, I took a different line between two trees that were just wide enough for me to fit. As I entered the trees, the tail end kicked to the driver's side. Given how steep the hill was, I knew if I stopped I wouldn't be able to start again without potentially getting sideways. Because of that, and the two big rocks at the top I had to get over, I kept up my momentum, knowing the mirror was going to be sacrificed. It was, but I made it up and over.
2. Bent the ZJ tie rod - here I underestimated how I would use the Jeep and figured the ZJ parts would be tough enough for my use. It wasn't. While trying to crawl through a series of "Black" trails down by the "Rock Garden" the ZJ tie rod, and clamp, got pushed into the lower part of the swaybar link, as seen in the picture. I was able to bend it back straight, with a winch line, but the damage showed a flaw in my thought process.
3. Honestly, my single biggest problem was the differential height - on 32" tires I'm at 9.25" (rear) and 10.5" (front) of clearance. I was able to mostly keep the front from being abused, but the rear really took a beating. This can only be addressed by larger tires, so I'm just going to have to focus on being a better driver. The other thing I can do is install the two cameras I have for the Insane Audio system.
4. The mini skids and wheels were abused - these are things I'm glad I did. The mini skids saved me from having bent lower front control arm mounts and the wheels performed their sacrificial role.
5. One rear shock kept popping off the bottom cap - this was a very minor thing, but annoying
6. The axle side track bar and rear sway bar upper link bolts loosened - My steering felt weird and I was hearing a rattling sound in the back, so I stopped to check things out. I found the bolts had backed out so far, they were just short of falling out.
7. The passenger front tire was into the SwayLoc, when stuffed and turned in - it wasn't enough to worry me, but I knew it was there.
None of this was bad, just demonstrated that I need to not underestimate what the Jeep or I can do together. Out of all this, getting an upgraded tie rod, and doing the tie rod flip,
I'm using the stock drag link and just replacing the tie rod with the BM one. If I bend the drag link after that then I guess I'll upgrade that too.
Interesting. I didn't know that was possible. Now I'll need to do more research!
Looks like that thread has been removed for whatever reasons.
Just want to say that I've really enjoyed following along on this build. Yours was the first build thread I read upon finding this forum last year, and I've enjoyed seeing it progress. Hope to emulate some of it some day.ha
Also, awhile back you posted a picture with a bunch of running medals...what types of races did you/do you run? A runner myself, although the finisher medal collection isn't nearly as extensive as yours
