Toughness personified
Anybody can do that! Not everybody can show an after picture with it being straight.
Here's one. Still straight!
Finally got around to installing mine today, only to find one end had the grease zerk broken off, and the other had the rubber all ripped up... so, taking longer than expected to replace :D Looking forward to jacking up the jeep by it lol.
Can someone please take a close up picture of the proper position for the passenger side clamp? I just want to make sure I've got it correct!
Bolt is down. If there is some contact with the draglink, you may need to add some bend to it.
Reactions: Irun
I posted this over in @jjvw's thread - but for those that don't already have a correctlync and want this, you can just buy the individual pieces. I believe this list to be complete:
* CorrectLync Drag Link $358: https://www.rockjock4x4.com/CE-9701DL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Drag-Link-Complete
* Steering Damper bracket $43: https://www.rockjock4x4.com/Steering-Stabilizer-Shock-Bracket-Kit-fits-1-1-4-Inch-Tie-Rod (thanks @JDM)
* BMB Tie Rod $185: https://www.shop.blackmagicbrakes.com/4340-TIE-ROD-HEAT-TREATED-4340-TIE-ROD.htm
* Currie TRE RH $82: https://www.rockjock4x4.com/CE-9701TRR-TJ-LJ-XJ-MJ-Currectlync-Tie-Rod-End-RH
* Currie TRE LH $82: https://www.rockjock4x4.com/CE-9701TRL-TJ-LJ-XJ-MJ-ZJ-Currectlync-Tie-Rod-End-LH
Puts you at $750 + tax and shipping all in.
[URL]https://wranglertjforum.com/th...re-i-want-to-build.9410/page-201#post-1047541[/URL]
I guess Rock Jock no longer sells the TREs? Savvy wants $50 shipping for two ends.
  • Wow
Reactions: rasband
Just placed order with quadratec a minute ago. Said item ships from manufacturer..... I'm scared
Reactions: L J
