The unfortunate TJ of the day thread
Probably cost a lot too
Other than the Autorella paint job, not bad! (Autorella was a small chain of el-cheapo paint shops in my part of California years back. They were notorious for doing zero prep, little to no masking, and painting over everything such as door locks, trim, and handles as seen here.)
They put the 4.0L decals in the wrong place too. :unsure:
  • Sad
Reactions: RINC
2004 Jeep Wrangler · Suv · Driven 52,000 miles Terra Flex Long Arm 4" Lift Kit Terra Flex Heavy Duty Tie Rods Terra Flex Front Sway bar quick disconnect Fox 2.0 Performance Shocks Fox 2.0 Steering Stabilizer ARB Air Lockers (front and rear) Warn Winch 9.5ti Warn Front and Rear Bumpers Warn Heavy duty tire carrier Warn Rocker panels Warn Dana 44 Diff Skid Plate Warn Driving/spot light combo AMP power step running boards Toys by Troy Sport Roll cage Metal Cloak Flat Fenders (front and rear) Re-wired with S-Pod and selector switches Bestop Upper door sliders with glass windows AIRAID cold air intake JET performance Chip Aftermarket Tranny cooler OMF strength rings welded on American Racing Outlaw IIs OMF Black rock crawling domes BFG KO2s, 35" Mastercraft bucket seats Bedrug carpet combo & tailgate liner Under seat locking security drawer Pioneer HD radio w/bluetooth Backup camera system Under fender LED Rock lights LED offroad under glow rock light kit Bronze Housed Bumper LEDs Custom reinforced Dana axle housings
$20,000.
  • Wow
Reactions: RINC and reddvltj
$20,000.
One would hope if the owner went through the cost of installing ARBs front and rear they would be smart enough to re-gear it at the same time.....
IMO it's not worth $20k but not a bad looking Jeep... It definitely looks clean and well taken care of...
I just messaged him. I'm curious to see if he just forgot some details.
Answer from owner.
It’s been regeared to 4.88. That was verified by ORI in Winchester, VA if you want to ask. Dana axles front and rear. It’s a 2.4L built for crawling out in AZ so, beefier axles weren’t really needed beyond some welded reinforced bracing, which you can see in the pics. It’s a great build that would benefit from a small block engine swap given it’s no longer used for crawling here in this area.
p.s. Who knew, beefier axles weren't really needed for AZ crawling? :unsure:
