My Jeep was hit (photos and questions)
OddJack
IL
I park my Jeep on the street. This morning I noticed the front tire is straight, we are required to turn the back of the wheels against the curb since we are parking uphill. Then I noticed the right tire is flat and the two front. wheels are not aligned. So someone drove into the Jeep from the side and pressed it into the curb so hard the the right tire punctured.
The crossbar is bent. I dont know why anyone would do this.
What are the possible damages and fixes? Can it be fixed on the spot?
Here are the photos after I installed the spare tire.
I would jack up the front end and spin the tires to ensure there is no wobble caused by a damaged hub or hub flange.
Check the steering box bolts and frame area where the box is mounted; couldn't hurt to check the torque on the steering box bolts.
Have the front end alignment checked once you replace the steering.
The ZJ steering assembly upgrade is money well spent...
I’d find a good body shop and have it looked at.
Might want to check out the frame for wrinkles.
And have a competent Jeep shop take a look at everything.
At the very least, have it aligned properly.
That's messed up. I can't understand how that happened without any other visible damage to the body or frame.
But yes, have a good body shop take a look at it and make sure there is no other significant damage.
