Time flies... my LJ pickup is 14 years old
14 years this month I drove my Retro Wrangler pickup for the first time. On July 26, 2008 I parked my 2006 LJ in the garage and 18 days later I drove it out as a pickup. I had spent almost a year designing the project and building the necessary parts to that design and the result was a kit of parts that went together very quickly. I call the project the Retro Wrangler because my design goal was to build a modern version of the classic Willys pickup.
As part of the design process, I did many concept drawings of what the finished pickup would look like, many engineering drawings of the parts needed for the conversion, and I even built a 1/25 scale model to make sure the proportions looked right from all angles. My projects are always about design - I typically spend more time designing than I do in construction, and that really pays off for me. The model:
Once the design work was done, I fabricated all of the necessary parts before beginning the modifications to the LJ. On July 27, 2008, I parked the LJ in the garage to begin the conversion:
Three days later, most of the disassembly was done:
The design called for lengthening the frame almost 24 inches and the easiest way to do that was to cut the frame at the back of the parallel section of the frame rails behind the front seats, cut a second LJ frame at the front of the parallel section and weld the two together. This provided the needed extra length was accomplished with only one joint on each side of the frame. I didn't know how to weld when I planned the project, but I bought a welder and taught myself to weld and then did all of the frame and sheet metal welding myself.
14 days after the disassembly photo above, I drove the new pickup out of the garage:
Back then I didn't do my own painting or sewing, so I scheduled the truck at a local body shop for paint and scheduled it at a local hot rod shop to resew the factory soft top into a half cab. Today I would do those tasks myself.
For a few months I drove it with the soft top while I worked on the hardtop. The soft top redesign kept the Sunrider feature:
The hardtop was fabricated out of a factory export CJ-7 World Cab hardtop I picked up in Wales when I lived in London two years before this project started, plus some parts from a CJ-10a half cab plus some extra sheet metal.
I haven't used the soft top since February 2009 because I like the hardtop so much.
I believe I met my original design goal to build a modern version of the classic Willys pickup...
JP Magazine liked the project so much they featured it in the July 2009 issue:
Soon after the hardtop was completed in early 2009, I drove the truck from upstate NY to Moab and tested the new truck on the trails at Easter Jeep Safari:
The truck now has about 130,000 miles on the clock (over 100,000 since it's been a pickup) and it's still a daily driver. A few weeks ago I added a 60 year old Willys ladder rack to the bed for carrying long loads (the rack slips into the stake pockets in the bed so it isn't on the truck all the time).
Back when I did this project Jeep pickups were just a memory and the Gladiator hadn't even been thought of yet. I still like my design much better than the Gladiator, I wouldn't trade my truck for a JT for anything.
I've got photos of every detail of the project so if anyone is considering building their own TJ/LJ pickup and has questions I can probably help.
I love it for what it is and that you built it and then have driven it for 100,000 miles and 14 yrs. I guess you love it too :)
The new PCM from WranglerFix arrived Friday and I installed it this morning.
As expected, runs fine. I'll keep the OEM PCM as a spare. I'm also going to acquire a number of need-it-to-run electrical components in the event the become unavailable, things like crankshaft position sensors, etc.
On another subject... I end up with a lot of preproduction prototypes to test from the companies that pick up my designs. For example, when I designed the Trail Kitchen that MORryde now markets, I ended up with 3 of them - the proof-of-concept prototype I built, a preproduction test Kitchen from MORryde and also a production Kitchen from them. I use the production one in the JKU and the LJ, the preproduction one in my trailer, and I disassembled the proof-of-concept one to make a basic fridge slide for when I don't need the full kitchen. It's pictured here in my LJ:
Similarly, I've ended up with a lot of preproduction samples from Overland Outfitters and recently a bunch of samples of their JK and JL door pockets. I disassembled some of those to make standalone MOLLE and seat-back pockets, with the idea of using them in my pickup and my LJ. In these photos, MOLLE pockets on a tailgate MOLLE panel (it's a JL tailgate but they'll work just as well on a TJ/LJ tailgate); pockets attached to my LJ door to add more storage there, and a pair of pockets attached to the OO seat-back zipper/MOLLE attachment in my LJ.
I'm trying to decide if I'll recommend these ideas to OO. Personally I like the look of these a lot better than ordinary fabric MOLLE pouches, but I don't know if other people will feel the same.
this is the coolest thing I've seen—props to you and your skills to do this.
*snip*
I hope you do. I prefer them over the fabric MOLLE pouches. I love MOLLE for its adaptability just not a fan of using it because it all has that "Wanna be Tactical" look.
Reactions: Woodrow
Yeah, I like them too.
Thank you. I think I will recommend them to Overland Outfitters. Since they tell me most of the products they sell are bought by JL and JK people, I sewed added another one for the collection this morning, it's designed to fit in the MOLLE recess in the back of the JL and Gladiator front seats.
It is a MOLLE pouch and could be used on most any MOLLE panel, but it also has a Zip & Go zipper on it so it can be used on the back of a JK/JKU seat or a TL/LJ seat, it's pictured here in my LJ:
I love the soft half top. Mopar had one but it didn't look good. Bestop had one. It looked nice but they only offered it in Black. I really wanted a Spice or Tan one.
Based on all the work I've seen you do, I'm sure yours out shined them both.
