I have some high praise for the Duroflex Control Arm, TJ/LJ Double Adjustable Aluminum Short Arms made by MetalCloak. I recently installed them into my jeep due to needing to adjust some driveline and wheelbase measurements. I had concerns about my front driveline bottoming out w/ a combination of the stock driveshaft, 3 inches of lift, and a HP Dana 30 in the front. Also I needed to make a slight adjustment to the pinion angle in the rear. This is the main reason I bought the arms.
But the ride quality these arms have given me is too incredible not to talk about. I am absolutely blown away by how little shock gets put into the cabin from bumps, potholes or ruts now. Some potholes that used to shake my teeth; I don't even feel anymore. The jeep just absorbs it as if I drove over a tiny twig. And I know my factory arm bushings were in good condition because I replaced them all due to being blown a couple years back. The flex is also a ridiculous upgrade. Such an upgrade in-fact, that I can no longer jack my jeep from the pumpkin; the flex is just that crazy.
Pictures and videos to follow, as well as a pre and post tests with my seismograph. I truly can't recommend these arms enough.
