Never finished installing the CB and decided rather than putting energy into that I am going to go with a Midland MXT275 GMRS.
The CB antenna uses one of the common taillight brackets with the coax running up to the front along the driver side of the tub. I am hoping to keep the antenna for MXT275 much shorter. Since all of my audio entertainment is available via BT, I never use the FM/AM radio and would like to repurpose the stock antenna mounting location for a clean install.
What is needed to mount the antenna that comes with the MXT275 in the hole that accommodates the stock whip antenna? Pros and Cons?
Is there value in adding the second 6db antenna for times a bit more reach is needed? And, can it use the same mount as the
