I want to bypass the clutch interlock switch on my '05 Rubicon and consulted my owners manual for guidance. Page 186 of the manual states that a 20 amp fuse needs to be installed in slot #28 in the the engine bay fuse block. So I got a spare 20 amp fuse, installed it into slot #28, and it won't lock into place. So I decided to try a jumper wire, but when I slid it in it went through the fuse block. Seems there are no contacts in slot #28. To further confuse the issue, page 294 of the manual shows that slot #28, Clutch Override, requires a 10a fuse. The manual doesn't agree with itself. Does anyone else have this fuse set-up in their Rubicon and, if so, how did you bypass the clutch safety switch?
