Eaton E-locker source
BlueC
TJ Expert
NC
Reactions: MountaineerTom
I've decided to go the Super 35 route, so I bought a Super35 axle kit from Revolution https://www.revolutiongear.com/prod..._tj_cherokee_xj_30_spline_upgrade_super35_kit, but they're only offering it with an air locker now, which I don't want. So now I'm trying to find an Eaton E locker for a decent price. Anyone know of a source for a sub $1,000 e locker for a 30 spline super35? Eaton part #19822-020
Sub thousand....... not since the china virus. They are available which is a plus.
$1,223.99 was the lowest I found with a quick search and was the same price across eight reputable companies, leading me to believe that Eaton requires MAP pricing.
Reactions: BlueC
A new E locker for under $1000? might as well ask for free installation too! Good luck.
I was going to wait until I had the locker before requesting installation. ;)
I just got a reply with $1083 + tax S/H, so close. Hopefully someone else pops in with another source to check with. I still have hope.
If I were shopping for lockers, and they were in stock for that price, I would be hitting the "place order now" button. ;)
  • USA Proud
Reactions: Zorba, JMT and Ocho
Can anyone confirm which bearing and shim kit I need to purchase with/for the Elocker? Quadratec has this listed for bearings
Motive Gear 3700 Differential Bearing Kit For Super 44 Detroit, OX Locker and Eaton E Locker Dana 30 & 35​
https://www.quadratec.com/p/motive-...-kit-super-44-super-44-detroit-ox-locker-kitsand suggest this for shims
Motive Gear SK47 Differential Shim Kit for Super 44 Detroit, OX Locker and Eaton E Locker Dana 30 & 35​
https://www.quadratec.com/p/motive-...4-detroit-ox-locker-eaton-e-locker-dana-30-35
Are these correct for the super35 setup? Is there a better place price wise to get them?
Did you ever make the purchase? I'm looking at the same thing now...E lockers are asspensive!
That's the only one I see that fits for a super 35 kit.
Eaton publishes the bearing and shim kit in their installation notes.
I could PROBABLY get away with upgraded 27 spline axles, but since I'm in there....
