A lesson learned—keep it light and nimble!
I'm undecided. Typically, I just use the seat brackets and ratchet straps to tie the boxes down. My main point for the indecision is whether the mounting plate would keep everything in place in the event of a rollover. I'd likely end up with ratchet straps anyway, so I'm not convinced going with the plate would provide any value. However, if it held up to the weight upside down, it would make access to the stuff better, when in the correct upright position. Make sense? :unsure:
I may have aired the jeep out enough last year to have my Dometic fridge/freezer full of water flip on it's side even though I had it strapped down. I'm liking the idea of locking things in place.
Why specifically 120 lb?
Nothing scientific here. When I started out I was carrying over 300lbs worth of gear, parts, tools, etc. on wheeling trips. However, over the last decade, I've been systemically removing items that weren't essential. I'm currently down to roughly 120 lbs, which seems to cover everything needed, for my scenario. It's also what inspired this build, largely because I noticed a significant improvement in the Jeeps ability to climb obstacles when weight became a conscious part of wheeling process.
That said, each scenario is different. If I were travel on trails out west, and was further from help, I'd likely up that weight to 160lbs or so. Again, nothing scientific here, other than getting to know my particular vehicle and when it starts to be negatively impacted by weight. You can obviously pick whatever number you're comfortable with! :)
I feel like I measured out the packout mounting plate in a TJ and it wouldn't work without removing the rear seat. If the rear seat is not needed, then I would definitely go this route.
That's another consideration for me. I wheel without the rear seat, but have it in the Jeep when I'm not wheeling.
Reactions: reddvltj and JMT
Confirm they lock in like the full size. It appears they do but I couldn't confirm it.
A single compact should fit behind a TJ rear seat according to my measurements. It will be pressing into the rear seat cloth. It has to be placed in the center due to the tailgate lock area on driver side and the electric area on the passenger side.
I confirmed they do lock in and release using the same type of mechanism as the full size.
I need to think about it, which I did walking around looking at socket sets, because it’s so small I’m not sure how useful it will be for compact storage.
One fits behind the rear seat with no issues. Two will technically fit, but you can't get the tailgate closed, due to the third brake light connector and the latch mechanism.
Today I was able to get everything packed up, in a compact form, for future wheeling trips. This was made possible by the Packout cases and bags.
With the case weight and a few extra tools I'm at 148 lbs. This is over my usual carry, but still within an acceptable range for me.
Tools - 59lbs
Fluids - 31lbs
Parts - 34lbs
Recovery Gear - 24lbs
Total space for the Packout set equals 22" Wide x 23.25" High x 16" Deep. :)
This is a post I'm happy to make. Although I haven't said anything, because I was unsure how it would go, I've been battling skin cancer over the last couple years. This past week I went under the knife again. This surgery lasted nearly 3.5 hours and left me with 23 stitches in my face. The results look good, so far, and I'm waiting on one more biopsy to come back. One positive thing I can say about everything I've been through, it gives you a new perspective on what's important in life!
Glad you are on the mend and things are looking good.
Keep the faith, Brother.
Reactions: Apparition and Irun
Stay strong. A positive outlook is so beneficial. My grandfather and father both have had issues with skin cancer on their heads and both have beaten it back, though my grandfather seems to have more issues with it recurring. He's 88 though and a fighter. My mom is recovering from a fight with Breast Cancer last year. She's done with the majority of her treatment, though they want her on an oral chemo for another 3 months...She's doing well, otherwise. You can beat it. Modern medicine is amazing, and the stiches will come out after a week or so.
Stay strong, and you have my number if you need to chat.
I'm glad everything went well with your surgery. Wishing you a speedy recovery!!
Reactions: RINC and Irun
Im glad the spots are healing well. It can be very scary when it’s your face. I’ve never had skin cancer, but my 50 days of neck trauma and loss of limb function gave me compassion for others with similar. Also very humbling. New perspective for sure! Prayers…
…50 days of neck trauma and loss of limb function…
That is scary. Careful on the slopes and MTB! Based on some papers I’ve read, I believe a full face and Leatt neck brace are effective but they are also hot and limit motion (which is the point).
Reactions: JMT and Irun
Pulling for ya & know that you got this. Stay strong.
