SOLD Most of what you need to convert an Auto to a Manual
Mike_H
autos are better - WRWD508
Grand Rapids, MI, United States
Price
700 + S/H
Grand Rapids, MI
I recently put a 42RLE in my 04 Rubicon. Need to get rid of the stuff that came out. The NV3550 is in OK shape, not great. Its loud in neutral (they all are) and it was tough to shift from reverse first without stopping (synchro issue I believe). The clutch is relatively new, maybe 15000 miles...but I've cooked it a couple times. When I did the clutch, I found the pilot bearing had seized and worn a groove in the input shaft. I had that fixed, and the shop painted the case black. Flywheel is still in good shape, but its gotten hot too. I replaced the fork, pivotball, and spring at the same time. Newer Mopar radiator…maybe 4 years and less than 15,000 (very conservatively) miles on it. New shifter boot in 2018. Most of the bolts are there too (flywheel, starter, pressure plate, CPS, Etc). Missing the engine wire harness. I needed to harvest some connectors and whatnot. Kinda don't really know what to ask for everything, so I guess I'll go $700. If you wanna kick in another 50, I can include the Miller transmission stand needed to rebuild the NV3550. I bought it with the intention of rebuilding this transmission, but we all know about the best laid plans. The stand is missing the reverse countershaft holder, but that is just a couples discs mounted on a piece of 3/8" threaded rod. I was going to build that when I got the transmission apart.
I can send LTL freight, if you want to set it up and pay materials for a crate. I can load the truck with a Hi-Lo.
Thoughts on selling just the Radiator? How much time/miles on it?
