Scrubbed and scraped all the embedded rust off my gas tank.
Thought I would put M5 riv ruts on the new filler neck but my tool's head is too big to snap the rivnut down flush. Should have just used sheet metal screws...worked (ish) for the first 20 years...2 were missing and 2 were through bolted...PIA to remove.
Tried a tack weld on the riv nut...nope...ordered another riv nut tool with a smaller head. Get to wait two weeks for Amazon...so much for Prime.
Just took the 06 for a spin to lock my work trailer at a job, fuel it and keep things working -
Also just a reminder guys- run that a/c a little these cold months so you have it when you need it-
Why I lock it -
Blew my clutch master cylinder. Backed down the driveway and noticed something dripping on the floor mat. Topped it off and made it back up the driveway
I had put in the LUK CRS011 last year, are there any better options?
  • Wow
Reactions: Kiwi TJ
Dorman one has ~200 positive reviews
MAS CC649041 Clutch Master and Slave Cylinder Assembly Compatible with Select Jeep Models https://www.amazon.com/dp/B0049MFPFA/?tag=wranglerorg-20
LUK has 20 4 star reviews
Schaeffler LuK CRS011 Pre-Filled Clutch Hydraulic Assembly, Clutch Release Replacement Parts, Clutch Hydraulics, OEM Clutch Replacement Parts https://www.amazon.com/dp/B004J1CZMM/?tag=wranglerorg-20
Reactions: red02tj
Of all the PO bullsh!t...looks like someone was trying to remove the roll cage and broke a drill bit...
Also... anyone know where to find a 52100218 fuel line...or should I just order a Dorman generic kit and crimp my own? For a early 97 4.0.
And PS it came right out with some vice grips...so wtf? Some people shouldn't be allowed to play with tools.
Reactions: Kiwi TJ and red02tj
Hey, I resemble that remark!!!
Reactions: macleanflood
My neighbor came over today to try and help me wire up my locker bypass like @JerryBransford suggested after I tried the Ken White way. Well after reading Ken's directions again, I found that I had connected to the VT/LB wire instead of the VT/DB wire. Well alls good now ifin you follow directions the first time. Can I blame it on old eyes?
Ordered Currie Currectlync from DPG. Great price comparatively.
Knuckle from VBB 16" kit (yet to be installed) on its way back to Blaine to swap out for a tie rod flip knuckle. Treated tie rod ordered from BMB along with the flip tie rod brackets & WRG soft shackles.
Really pushing to get this Jeep back on the road.
