Check out @DrDmoney's thread. He made a set for his GR bumper back when the 6061-T6 threads were exploding.
Yep, already talked to him about it. Thanks.
RMS was dripping oil all over the floor. Cut the downpipe to make getting the pan out easy. Will reattach it with a band clamp, so it can be removed easier in the future.
Smart idea. I should do that. I'm dreading replacing the RMS
Does your exhaust not a disconnect point after the 3rd cat? Or, were you avoiding dropping the skid?
Down pipe went solid all the way to the third cat.
Used a Mopar RMS this time. Let's see if it holds up longer than the last couple of Fel-Pro versions. There is a very slight exhaust leak at the cheap band clamp I used. It's one I had already, but will be replaced with a Walker clamp, when it gets here.
Started the spring cleaning. Pulling off stuff that's in the way and doing a full detailing. Passenger side has now been cleaned and waxed.
