After building my Jeep this winter Im starting to plan for other things I want to do with it next winter and an atlas is on the list, while I’m doing the atlas I kind of want to ditch the 32rh that I have never really been a fan of. It’s always been leaky due to the torque converter lockup connector which I fixed but now it’s not locking up but atleast it’s not leaking anymore and I don’t really care about lockup since this is a trail rig only, the only time it sees the road is if I have to travel a short distance to a trail from my trailer.
The swap to a aw4 will be simple as I won’t be using a tcu and all the electronics will be in the shifter, this part is already all figured out. The part that I need to do some research on will be do I need to tv cable since what im looking at doing will do away with the tcu and turn it into a manual shift pattern?
Also if anyone has any info on what it will take to get it bolted to the motor?
Thank you for any info in advance.
