Thanks to @nk24 for all this information!
Below you'll find a guide to replacing all the interior lights on your Jeep Wrangler TJ with LED bulbs. There's links to the bulbs you'll need, and you should find it's a pretty straight forward job.
Depending on what model of Jeep you have (i.e. Rubicon, Sport, etc.), you may need more or less bulbs for your rocker switches. I say that because an automatic Rubicon with a hardtop has 4 rocker switches, whereas a Sport model with a manual transmission and no hardtop may only have 1 rocker switch. It just depends on your model and factory options.
Parts Required (1997-2002)
Parts Required (2003-2006)
Tips
- Cluster (5 required)
- Footwells, Sound Bar and Shifter Lights (4 required)
- Hard Top Light (1 required)
- Rocker Switch Lights (The amount required depends on how many rocker switches your TJ has. Make sure to get the 4mm bulbs.)
- HVAC Lights (3 bulbs required. Make sure to get the 4mm bulbs.)
- Footwells and Shifter Lights (3 required)
- Sound Bar Lights (2 required)
Tips
- Rocker switch lights: You'll need 4mm LEDs for the switch light illumination bulbs, and 3mm LEDs for the switch indicators (the lights that come on when you turn the with to the on position). The number you need of each depends on how many your particular model has.
- If you have a Rubicon model, don't bother trying to replace the axle locker switch unless you're experienced with soldering, as those bulbs require soldering.
- Remember that the cluster and the rocker switch lights are polar, meaning that they have to be oriented in the correct direction. Make sure you test them before you button everything back up.
- LED replacements are much brighter than the stock bulbs. If you're going to do one switch with LED, I would recommend doing them all.
- There are a few differences for the '97-'02 models. Cluster and rocker switches are the same as above. There is only one light in the soundbar, and that is the same as the footwells/shifter as shown above. There is a separate light in the rear of the hard top, and that is the same as the lights in the sound pods as shown above.
