Vas is das?!?!
The engine jumped out
Vas is das?!?!
No, I was still getting small flakes of glitter in the oil filter after 3 oil changes. Nothing was knocking, so I had a hunch it may be cam bearings. I was right. I used a borescope through the OPDA hole and saw the bearings were squished out at the bottom. So, I pulled it to replace the cam bearings and put a lighter valve spring in. I also polished the cam journals and replaced the expansion plugs. It looked to me as if the machine shop installed the cam bearings incorrectly. The front two were installed at 2 o'clock with the oil feed holes lined up with the block. The rear two however were clocked at 12 and the feed holes were blocked.
wow...with as many stories as I hear about machine shops screwing up engines...I guess that is something else I'm going to need to learn to do.
I bought this machine earlier this year for that exact purpose. I keep looking at auctions for more stuff. I would like to get a wash cabinet, crankshaft balancer and cylinder honing machine. I think with all that stuff I should be able to do quite a bit of engine work in house.
I hereby bestow upon you the coolest freeze plugs on a Jeep I6 award. Keep the speech short and don't mention Will Smith's wife please.
I think I got screwed by my last machine shop too despite taking it to a high end race shop. I'm just gonna run it until it blows though![]()
Big Black Object?![]()
Damn, what symptoms are you dealing with?
I mostly hear about assembly issues. It’s not just the I6, either. My other project, the 78 gmc motorhome, seems to have even more horror stories about shops rebuilding the big block olds like it’s a big block Chevy and really screwing them up.
What do you mean? Just not paying attention to olds specific assembly techniques and trouble prone areas?
That’s a nice one. I have a VF5 with a 5th axis. It’s amazing what these machines can hold for the price you pay. Very good value.
Big Block Oldsmobile. And it's blue
I won't go in to all the back and forth I did with the shop just getting the work done, but suffice it to say I am almost certain they sent it out to some other shop to have the work done and didn't do most of the high end specialty stuff I paid for like using a torque plate, line boring, and spin balancing to name a few things. They sure did bead blast the block though despite me saying I didn't need it (and charged me for it)
It had a TON of sparkle in the oil and filter pleats on the first oil change after break in. It has gotten dramatically better since, but there is still a nice shimmer in the oil (nothing visible in the filter). I think it's bearing material. Hopefully they just epically screwed up the cam bearings and they clearanced themselves similar to what Jezza saw. Those bearings aren't *as* crucial to have perfect like the main & rod bearings for example.
