Rear floor pans were delivered today
This mornings progress:
-Drilled out some of the torque box spot welds
-Removed fender (easier said than done!)
Discovered what I think is a bad seal job which may explain why my driver side rusted out so much worse. I broke off one of the bolts (first one) for the fender at the front before I realized I should have removed the headlights to spray liquid wrench and use heat.
As for the fender bolts into the tub...this was a great time to do that because I had the bottom opened up and could spray liquid wrench into the back of the bolts and heat. It looks like only the bottom one was rusted badly.
Fender moved
See the gap at the corner where light shines through? I could be wrong but it looks like the sealer didn’t get into the corner like it was supposed to.
The four bolts holding on the fender. Bottom one is rusty but top three look good and came out easily.
Spot welds removed. It was hard to find them among the rust, bondo, etc (from an earlier bad attempt by me to fix the rocker rust)
