Hi everyone, hoping some one can give me some ideas.
Some background Info. Engine and Transmission both professionally rebuilt.
In the process of fixing a leaky rear main seal under warranty, the mechanic damaged my PCM.
probably with a Battery Charger. They installed a new ECM and after getting my TJ back , it is now throwing a P0740 Code.
I noticed that the transmission TQ Lock out is not locking out. i.e. RPM never drops once in third gear.
Its suppose to drop 400 or 500 RPM once up to speed which it never does.
Took it back to Transmision shop since it is also under warranty and initially they said it was just an adjustment.
when I test drove it the shifting seemed smoother 1st thru 3rd gear but again the TC never locked up. After 3 miles f test driving it the
Check Engine light is on with the P0740 Code so I left it with the transmission shop to trouble shoot again.
My question is this:
Does the PCM tell the transmission to lock up? or does it simply lock up due to transmission pressure?
Either way the TC is not locking up as it never drops 400 to 500 RPM in 3rd and above 45MPH.
I have personally checked the wiring going to the transmission and all appears clean and undamaged and even reseated the ECM
Just trying to Trouble Shoot to see if its the TC Lock Out Solenoid in the transmission or if its the replacement ECM?
Trying to figure out if the engine mechanic inadvertently thru in a Manual PCM instead of the automatic and left him a message to try and find out which company he purchased the ECM from. Figured the company who supplied the re-manufactured ECM should be able to tell me.
Again, just trying to trouble shoot to know if its Transmission issue or re-manufactured ECM Issue.
