My passenger side underdash light was out...so I desided to do a cheap upgrade. So of coarse I jumped on some websites and looked up what lights and things I needed. I found the conversions on Amazon of coarse.
https://www.amazon.com/dp/B01M5JWBMA/?tag=wranglerorg-20
https://www.amazon.com/dp/B008DY9CSQ/?tag=wranglerorg-20
Then I removed the original Bulb and cut the wires to the original mount as close as possible, leaving as much stock wire to work with...
I needed to drill the back of the original mount out just a bit to fit both wires thru, then install the new LED adapter and it locks itself in place.
Then rewire it back up..Test as you go for connection...
Then Screw it back in original location...
LED's come in multiple colors...these are blue (picture doesn't represent real color well), but they are twice as bright as stock bulbs, last longer and are cheaper to buy and use. These same size bulbs worked great in my Stock sound bar center light in my 98' TJ also. Hope this helps some of you, it worked for me.
