Gun Rack Options
Intimnasc
Jeep the Other Harley Davidson
Lifetime Supporting Member
Fort Worth, Texas
I would look at making your own. For a whole lot less.
This only holds one gun and the radio, but you could modify the basic concept.
One piece of 4' strut channel, blk. 2 blk vinyl coated chain link fence tension clamps and bolts, around the roll bars and bolted through the strut. 1 Kolpin Rhino Grip XL ATV gun mount. The clamps fit under the padding and come out the existing holes.
Long as you have the head clearance in a pinch. My buddy has one like the pic in his xcab taco, very cool set up. I had one of the between the seats floor mount ones I likes. Not entirely out of the way but they all have their good and bad.
Yeah I have access to unistrut and parts that idea intrigues me. The headroom thing had me concerned with the overhead as well as interference with a bikini top or anything else.
It clears the fold and tumble seats and I had my 6'4" or so buddy lean forward in the passenger seat as if he only had on a lap belt, plenty of clearance.
I used a solid piece of strut and just drilled holes where needed.
I am looking at the below gun rack to hold a couple of ARs or other weapons up and out of the way. As we know real estate in these things is limited. I'm also looking for a pistol safe preferably a biometric if there are any suggestions.
https://www.redrock4x4.com/product/...-universal-some-adaptation-may-be-required-3/
I cut one side off of that rack and have the holder flipped above the centerline of the bar.Takes up much less room and it clears hard and soft tops with an AR10. They aren't little guns
Post in thread 'Project Basketcase!' https://wranglertjforum.com/threads/project-basketcase.67755/post-1273971
I certainly wouldn't use biometrics or ANY electronics in a gun safe.
Actually I was looking at the Valtek sliding safe and hoping to mount it somewhere between the seat and console. That's all maybe just exploring options. The Valtek also has a remote hidden button option. For; instance tap a button with my left hand so I can pull with my right.
You gotta do you - but I don't trust any kind of electronic gun safe, much less anything biometric. My suggestion is something with a simplex lock - still fast and no electronics.
The tuffy underseat boxes are an easy choice
Reactions: StG58 and BlueC
I'd have one, but the one for the 06 fold and tumble seat is tiny. Not really great for quick access though as it has to be locked when driving.
If you don't want the box locked you can leave the drawer open an inch.
