Not so much what I did today, but what I've done over the last several weeks. Getting ready for a group run to the Magruder Corridor in Northern Idaho.
https://www.fs.usda.gov/recarea/nezperceclearwater/recarea/?recid=16482
Over the last several weeks I've:
Upgraded the battery to a 775CCA AGM Superstart with dual terminals (thinking winch)
Replaced the starter motor
Changed the oil
Installed 2" Rubicon Express puck lift, Bilstein 5100s, MetalCloak rear trackbar and sway bar discos
Changed (rather added) transfer case fluid - when I drained it only about 2 tablespoons of blackness drained out. Required the full 2.2 pints to fill it.
Replaced 2 rear driveshaft U-joints with new Spicer 5-1310x. This was a bit of a PITA. Used the bfh/socket method which worked fine, but I couldn't get one of the needle bearing caps off the t-case yolk end joint. I think it was OEM. Ended up cutting the joint itself to get it out of there. Love my grinder (so long as I have a replacement part handy)!
In anticipation of the winch install (new Warn M8000S sitting in the back of my truck), I started on my stock bumper modification earlier this week. I cut off the PO's homemade hoop and light tabs to make room for the Rough Country 1/4" winch plate. Ground everything down. There were some mild rust spots where the PO's welds weren't sealed. Pulled the bumper and prepped it really thoroughly - cleaned, sanded, steel wool to the rust spots, primed and painted. Looks good. Going to mock up the winch today. Not going to crank it down just yet. I'm waiting for some beefy d-ring mounts I ordered from Summit Racing that I need to prep/paint and will bolt to bumper.
I also have the Moog ZJ tie rod/ends in the garage which I prepped/painted along with the bumper. Waiting on MetalCloak front track bar, steering stabilizer and rear sway bar links to install in one session. Hopefully next week, but MetalCloak is kind of slow to ship compared to rest of the world . . . Finally, I've some Redline MT90 coming this week for the transmission and I may just pay my regular mechanic to service the diffs because I'm tired, my back hurts and I'm not sure how fun I think some of this stuff is! Gonna go clean my K&N air filter and mock up the bumper/winch. I'll post a picture of the bumper/winch in the front bumper thread later. The list goes on, but that's where I'm at for now . . .
