Following your build, thanks for blazing the trail for me!
Wondering what your thoughts were on final lift height / driveshaft angles.
Your UCF extra should lift your transfer case 2 1/2" over stock. Then you're adding 4" suspension lift.
How that's going to work out with the driveshaft angle?
Unless the UCF is designed as a lower profile than the stock skid so it doesn't raise the transfer case by the full amount of clearance gained?
I'm slowly gathering parts for my build. (also an LJR) I wanted to start at the transfer case.
I've got the UCF ultra high clearance skid (somewhere around 3.5" higher than stock) and their low pro mount sitting on the floor waiting.
MORE 1" MML
1 1/4" BL
Savvy cable shifter
Was also wanting the $avvy control arms (yet to order) But I think I'll go with 3" springs. (because the transfer case is way up after TT) Going to run 31's until they're wore (or I'm sick of looking at them!) and stop at 33's
Suspect we will both need DC rear driveshaft when all is done.
I've researched builds identical or close to mine that had folks being fine with the rear drive shaft (no vibrations) and others going ahead and replacing it. I'll have 4" Currie springs with a 1.25" Body Lift and 1" Motor Mount lift along with the double adjustable upper and lower control arms from Savvy. I asked UCF which skid plate they recommended for the tummy tuck with my lift and transmission and was told to go with the extra clearance model not the ultra clearance with lopro mount. Going with the ultra would have increased angles even more from what I gather and I also didn't want to deal with the possible vibrations from the transmission by using the lopro mount.
I'm hoping that with the adjustable arms, motor lift and extra clearance plate that my angles will be within range. Worst case we'll take a measurement once its all installed and order a DC driveshaft. Good luck with your build and I'll hopefully let you know soon what I find with mine.
