The alarm went off, horn beeping, beeping, beeping, so I grabbed the key-fob and pushed the unlock button .... the lock button .... the remote start button and the beep, beep, beep continued.
I went to open the door and it was locked and not responding to the unlock button on the key-fob so I inserted the key into the door-lock, turned it, and not only did it not unlock but it froze in the unlock position and grabbed the key.
Now the key is firmly stuck in the door, so tightly it could be part of the door. No movement at all. So tightly there is no room to spray WD40 in the slot.
I got a wrench and as I approached the battery terminal the beeping stopped. But the key, is still stuck in the door and it won't budge.
HELP !
HELP !
