Thanks, guys... Yeah. I've got the floor mats out and am trying to see if the floor will dry out. Does the heat or ac need to be running for the core to leak?
The coolant circulates thru the core regardless of any settings so there is always flow thru the core.Thanks, guys... Yeah. I've got the floor mats out and am trying to see if the floor will dry out. Does the heat or ac need to be running for the core to leak?
A friend offered to run a compression test for me [emoji51] maybe I'll learn something useful from all this
If there is an easy way I sure dunno how it'd be done. I guess you could plug the heater hoses temporarily and see if the leaking stops. Like with something like this kit made to do that particular job... http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=301079083678Pretty safe guess it's heater core... Can one test that theory without pulling everything apart?
If the heater core is leaking there should be moisture around the heater box under the dash. Is the foam seal between the heater box and firewall wet?
If you don't have the tools or skills to work on it yourself, then yes, I would definitely get it to a shop ASAP before it leaves you stranded. If you're losing coolant but you're 100% sure it's not leaking under the car or into the car (heater core), than you almost certainly have a blown head gasket which is letting coolant mix into your oil. That's the only plausible explanation, since your coolant has to be going somewhere.
