My LJ Thread - A MrBlaine Spec'ed LJ Build for Daily Driving and Weekend Adventure
Sounds right to me! Duratracs come in C load rating in that size as well, just not in a true 35" size. The 315 ends up being a 34.4".
I think duratrac in a 35 or 315 for 17 inch rim comes in load ranges E and D respectively.
35 is 34.8"
315 is 34.4"
Sent from my SAMSUNG-SM-G930A using Tapatalk
35 is 34.8"
315 is 34.4"
Yep, I stand corrected, it's a load range D. Still, not bad. My D load range tires ride much nicer than the Es did.
You're just not inflating it enough. If you take one of those "truck tire inflators" that are rated to a few hundred PSI you should be able to make it a true 35.
I've been mildly curious about how much of a size/psi difference there is been a cold and a warm tire, or what happens when I drive from 5k to 13k feet above sea level.
I've watched the PSI change on truck tires with the dash psi monitoring (Chevy Silverado). It can change a psi or two as the tires change temp even under heavy trailer and bed loads.
I haven't tested elevation (beyond maybe 2k feet in normal driving) but it looks like it's also minimal: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=167
Reactions: jjvw
Those are Fox Factory Race Series 2.0 Smooth Body shocks.
They won't fit on a stock TJ. You have to outboard the front and rear shock mounts in order for them to fit, among other things. Definitely not a bolt-on affair.
Sorry I should have clarified. What shocks would you recommend for an LJ outboarded just like this. The next mod on my list is rear outboard.
For an LJ with a rear outboard, get the same shocks I linked to above. Those are probably the most commonly run shocks for outboarding.
I have them on mine as well (which is also outboarded), and they ride fantastic.
I would suggest getting them from @pcoplin as he is the suspension guru. He can tune them to your liking just like he did with mine. It makes a world of difference. Anyways, talk to him, he will hook you up!
You can outboard any shock. Most do it so they can get more travel and use basic shocks to do so, I do it so I can put a high quality shock on there. Most done with 12 inch 2.0 smooth body shock, any brand you like really: Fox, Radflo, King, SwayAway,ect.
For 2.0s I think Fox is the best buy.
And thanks for the props Chris. But I am no guru, far from it. I have just played with valving enough to know what rides good and what doesn't. :D
Okay, well you're the best suspension guy I know, haha (not that I know many).
You came highly recommended from others (that's how I found you).
