I have a 2002 TJ with 153,000 miles on it.
Full tune up in winter 2017.
One month ago the jeep was running so rough and multiple codes came up: P0320, P0300, P0301, P0306.
I took the jeep to a local mechanic - he was unable to diagnose and suggested the jeep dealer. The jeep was at the dealer for 1 month.
Fixes included ignition coil, crank sensor, all of the plugs replaced, injectors switched around and cleaned, replaced the injector O rings, checked gas tank and fuel pump and filter. Ran the jeep for long drives and the P0301 misfire code continues to come on -missing slightly they say. They have had 5 techs and a foreman review it and are stumped. They said that everything checks out fine and perhaps its an engine internal error. I have it home now and the light just came back on.
What else can I check that the certified mechanics could miss? Bad, loose, cracked fuel cap? Bad battery? Suggestions please! I have spent hours and hours trying to figure this out.
Thank you!
Thank you!
