Tail gate compatibility
wraith1516
Michigan, USA
i was told an oem tailgate from a1999 tj would fit the 05 tub i bought the gate is oem but it wont close it like it is to big and the striker wont move far enough to let the catch get ahold of it . Am i missing something? i would put pics on post but haven't figured out how
I put a gate off a 2000 I believe on an 04. Fit fine but the lock cylinder was smaller on the older gate. I had to file the hole out to get the original lock cylinder to fit.
82350
82351
Click on the icon in the top corner and the box will pop up, click on the box and ur photos will come up
I’m also in the process of replacing my tailgate from previous owner backing spare tire into something. My Jeep is an 03 and the tailgate I’m putting on it is like an 01 if I remember right. My tub is bent by the tailgate hing enough to keep it from working. Might look and make sure yours isn’t tweaked as well.
upon closer inspection im thinking the tub is tweaked not a tailgate problem witch sucks because im in to this tub for $900 100 for the sandblasting $400+ for the raptor liner and consumables plus my time
That doesn’t answer my question. Will the gate fit in the hole squarely without any hinges mounted to it or the latch in it. Post a picture of the way it fits in the hole so the entire gate is visible
Yes tailgate fits in w/o sttiker or hinges finally got hinges off tailgate had to drill out all 4. ALL jeep engineers should have there balls STOMPED ON FORCEFULLY AND REPEATEDLY!!!!!!!!! what were they thinking putting aluminum hinges on it
If the gate fits in the hole without hinges or striker and the gaps are even all the way around it’s an adjustment issue.
Bolt the hinges to the body because there is no adjustment on the body side. Fold up two small pieces of cardboard and put them on the sill of the tub. Place the gate on the two pieces of cardboard and center it from side to side. Bolt the hinges to the gate. There should be about 1/8 gap across the bottom and 3/16 on each side. Then put the latch in.
Reactions: wigsajumper
I could be wrong but my understanding is that the early hinges are different (don't know by how much) than the later hinges. Which hinges are you using?
