Need some input on a driveline vibration I’ve developed. I have a couple ideas of where it may stem from. Before I start throwing parts at it, any ideas?
A little info on the Jeep... it’s a 99 TJ. 150,000 miles. 4.0L 5speed with a 4” skyjacker lift w/TC drop. Fixed lower control arms (I assume they came with the skyjacker lift. PO installed this lift) Stock upper control arms. 231 t-case. On 35” mastercraft courses MTX’s. About a month ago, I had some frame rust repair done on the cheap. And about a week ago I replaced both motor mounts and the transmission mount with rubber OEM replacements from crown automotive.
The vibration doesn’t seem to be any better or worse at any particular speed. It’s most prominent when taking off. Almost like a worn out transmission mount.
I’ve tried dropping the front driveshaft, not much change. I’ve tried dropping the rear driveshaft, again not much change.
So my theory is, I’ve gotten u-joints in both shafts that are on their way out (what are the odds of this
). My other theory is, when the rust repair was done, it dropped the skid a bit lower, causing the vibration...?
Should I start by replacing u-joints, or should I go grab a couple handfuls of washers and re-shim the skid?
Photos of rust repair:
Photo of driveline angle:
I know the proper repair for this is a SYE w/DC driveshaft. That is coming in the future, but isn’t in the works for a bit. Any suggestions?
edit: the TC drop is square tube style.
