As title says, I pulled the skid plated from under the transmission without realizing that it was more than a shield, and supporting the transmission.
It sat for several days as I was taking care of some frame rust and rust on the plate itself. It has just been sitting, not moved at all and not put in gear.
Now that I went to look at it after seeing a post mentioning supporting the tranny, the drive train was sagging noticeably. I don't recall seeing this when I first pulled the plate, but I suppose it could have. So now I have supports under where the small bolts are.
Is it likely anything has been damaged?
