Is this the sway bar end link? And can anyone point me to a recommended replacement?
With no lift i would go cheap. If you can wait order online. If you need them fast i agree with @oldditchdoctor and just hit up orileys.Thanks gents. No lift. Is it worth upgrading with no lift? I live in CO and was running intermediate (and a couple advanced) trails this summer. Is this an age thing or does this suggest an upgrade is needed?
Those will work fine. Replace both.I take it that replacing both at the same time is the best plan?
Edit: these seem cheap...should they be avoided? https://www.1aauto.com/1997-06-jeep...MI4-uJ3_Lr3gIVSp7ACh2nYw2yEAQYCSABEgJxTPD_BwE
I can see you're on the bump stops a lot. Besides disintegrated jounce bumpers, there are rings on the pad that indicate metal to metal contact. I suggest measuring the distance between lower and upper spring perches. Healthy stock springs at rest will be twelve inches, plus a half inch for the isolator. My guess is the springs are sacked, and that side's shock probably has a big dead spot. That calls for new jounce bumpers, springs, and shocks.
Adding to cart for next monthI can see you're on the bump stops a lot. Besides disintegrated jounce bumpers, there are rings on the pad that indicate metal to metal contact. I suggest measuring the distance between lower and upper spring perches. Healthy stock springs at rest will be twelve inches, plus a half inch for the isolator. My guess is the springs are sacked, and that side's shock probably has a big dead spot. That calls for new jounce bumpers, springs, and shocks.
you need longer links. its not a good idea to drive on road with them disconnected
That's what I did... New longer links... I made them by a turner... On the road all was OK... But last week It was the real test... Trip in Sahara of Tunisia... From the first dunes and the liks are broken ... And just after the wing widener are hit in turn ... I'm really frustrated ... The other 4x4 did not have this problemyou need longer links. its not a good idea to drive on road with them disconnected
