06, 4.0, no cold air, been to evidently the wrong repair shop twice. They can't find leak, dyed the system still nothing
It still could be the evaporator behind your dash. If the shop didn’t check the evaporator, that’s where I’d look next, although it’s a pain to get back thereGoing to do another recheck on electrical, soap test, hardware checks, just po'd on the shop that failed.
I’ve heard that the TJ X model does not come with AC? Is this true or false? I’ve been told there is not even a button for AC, that it is manufactured closed but if you choose to have AC, it can be replaced?
Ok. How much ya think?If it was ordered with A/C it came with it. A/C was available on all TJ models. The HVAC faceplate did not include A/C if it was not ordered.
An aftermarket kit is available thru Jeepair if you so choose. Piecing a system together from various sources is generally going to be more expensive.
On A/C systems you should never use a smoke machine as it will introduce unwanted particulates into the system and as the system is high pressure it normally requires high pressures to discover leaks.X2 On performance test
I think autozone has a manifold gauge you can rent. Hook that puppy up and see if you have pressure. No pressure usually means there’s a bad leak. The A/C shop could have done this quick if they would have vacuumed the system to ensure there wasn’t a leak.
Also with the manifold gauge on you can see when the compressor is operating.
I like to use a smoke machine to check for leaks.
I have an X and I have AC. It doesn’t work, but I have it!
My mechanic (ex-Mechanic now), told me it was the compressor. So I spent $600 buying Chinese crap compressor and new o-rings throughout the system in the Engine bay, just to have AC for 3 days, then it crapped out again. So, I called the mechanic and he said it was probably the evaporator then. NO SH— Sherlock! So, I’m not paying him to fix it. I haven’t got to it. I’m still venting and that was a year ago. I just want to have AC in the summer if you know what I mean. Seems I’m not destined to have it. The job actually scares me a bit.Still?
Or, you just haven't found time to get to it?
I'm curious. My '06 was new to me in the fall so, when I tried the ac the other day, it didn't work. I recharged the system and it worked. It's been about a week now, maybe I better Ho see if it still works. You've got me worried. (Not a lot though. I don't use it that much. And I may then covert it to OBA)
