Yup agreed with everything you said! A long time ago KubotaSwappers told me how to tune the V2403 and I really need to call him again and write it down, it was a good method for tuning the mechanical fuel pump with a boost and EGT gauge going up a long hill while monitoring your EGT temps so that you don't melt the head and you aren't rolling coal. I'm not a fan of rolling coal, it's a waste of fuel, so I'll be looking to fine tune the performance of my V2403 so that I have as little smoke at the back as possible.
I do plan on doing some light towing with the Wrangler. The heaviest thing I would tow is my jetski which is well within the towing capacity of the Wrangler. Actually I'm looking at a used 16ft pontoon and I just checked on it's weight as well, they are lighter than I thought so I might use it for the pontoon as well, but I would want to test it out first.
At some point I want to do a LJ Wrangler or extend a TJ Wrangler for better towing capacity, I think the longer wheelbase helps more than anything else truthfully.
-Grant
I hear so much stuff about towing and wheelbase. I really think the difference is over played. I worry about the transmission and braking mainly. I love towing with the TJ as long as I'm not smoking my clutch or being pushed while stopping. I know I don't have an extreme amount of experience, but my big utility trailer is at the max of the TJ rating when its empty and I use it fairly often. I have a long bed extended cab truck and the difference I notice is from the brakes, transmission, suspension, and fairly large diesel engine. It's much harder to back up and maneuver than the TJ.
My granddad told me about towing with the WWII Jeeps, early CJs, Scouts and other SWB vehicles and the only thing they were ever concerned with was going forward and making it over hills. Sometimes they'd require 4Lo.
Obviously that's extreme, but until you're really pushing it or hauling sloshing fluids or something, I find the only things that REALLY matter are brakes, what's between your ears, transmission, weight, suspension, and torque/gearing. If it's on a regular basis then adjust, but for a boat, I used often I'd go get an old F-150 for $1k before I modified my Jeep.
I have a conspiracy theory on the R2.8 and towing over 3k lbs with the TJ, that the EGR is kinda throttling me on takeoff. I'll eventually delete the EGR and when I go to the Atlas I can use 2Lo and shift to 2Hi without stopping, if I'm towing heavier stuff. Also I'm going to go away from 3.07s eventually.
I've also been told that in snow/ice the Jeep is too short of a wheelbase. I think side by side short is slightly worse, but within most people's capabilities that have a little bit of experience. I agree that there are times longer wheelbases are better, but I think typically slowing down fixes most situations. I can't comment on rock crawling and wheelbase.
Now the space you can potentially gain from wheelbase, I can't argue with, but again you can still wheel in a Jeep and you can still go cross country. It's been done with less.
