How-to stop a whistling light bar
S.McArthur
Greenbrier, TN
This should stir the anti-light bar pot; anyway, quick and simple fix. As with most projects, start with clean surface. There is no reason to spend more than $15/15min fixing this issue.
Time: 15min
Tools:
  • 1 Can of Beer (User preference)
  • Scissors
Materials:
  • Door/Edge Trim: ~$15
Prior to starting, look at your light bar and move it up/down while seeing where the closest gaps between the fins and windshield are. You can probably start in the center and work down 2-3 fins and be fine.
Set your light-bar angle how you want it; not pointing in to the trees like you have most likely had it to stop the whistle. I did not see any reason to go any higher than the center fin, the wind comes from the bottom side, that is your issue area.
Step 1:
Purchase Door/Edge Trim
92293
Step 2:
Open Beer, take a chug
92294
Step 3:
Either cut to length your strips or snip off the end when you reach the other side of the light bar. Insert door/edge trim onto preferred heat sink/fin.
*I found through that it appears to be the heat sink/fin with the smallest gap to the windshield that cause the issue. *
**I started from the bottom heat sink/fin and worked up since I had 18ft of material. **
92295
Step 4: Another sip of beer.
Step 5: Repeat step 3 until you have run out of material or satisfied.
92297
Step 6: Finish beer...bro down with the boys
I'm sure this will help a lot of people out, especially since I see this question being asked very frequently :)
Job well done!
A little tid-bit I learned, it was only one fin making all that damn noise! My buddy reached up and put his fingers on the fins in hopes of stopping that freaking noise! It stopped! I had just installed the light bar before I took the jeep on a week long Elk hunt and OMG to my surprise,,, the noise coming off that bar! I did the door edging on the one fin and poof, tah-dah, viola what ever,,, SANITY!
Reactions: S.McArthur
Time: 15min
Tools:
- 1 Can of Beer (User preference)
- Scissors
Materials:
-Door/Edge Trim: ~$15
Step 1:
Step 2:
Step 3: Either cut to length your strips or snip off the end when you reach the other side of the light bar. Insert door/edge trim onto preferred heat sink/fin.
The amount of edge trim needed on the fins is very little. The reason they "whistle" is they are vibrating at a very high speed. Cut pieces about 3" long and add them about 1/4 of the way in from each end and that adds enough mass to dampen the vibration.
Agreed, I had 18' of material, a full can of beer, and time to kill. That is the only reason I did the other fins.
I tried the little 3 inch pieces but they kept coming off, so I just went all the way across the dang thing and its still on there today. A beer would have helped! Sheesh I was stuffing ear plugs in between the fins, carved sticks, Styrofoam! Yeah! All helped but would come out eventually, (and looked stupid!) when I got home I fixed it right. What I was hoping to point out was that it can be determined which fin or fins are making the noise, if that was already done and I missed it, just ignore me. Food for thought, I wonder if the fins were crimped like on a condenser or??? it would add rigidity and stop the bad harmonics without adding edging.
Thanks for this, I've avoided adding a light bar because I didn't want to deal with the noise. Much thanks!
Didn't somebody post this how to last month? I remember this exact same thing...
It was a thread that turned into light bar bashing and lost in the sea. There were tales of $125 fixes and big bang theories of how to fix the unfixable lightbar whistle.
I was doing mine and drinking beer, figured I'd take 4 pictures to show how cheap an easy the solution is.
I may have been one of those bashers... Sorry. If it makes you feel any better, I also ended up with a light bar for the benefits on the trail.
Doesn't bother me at all, if I got butthurt over internet comments, I'd still be wrapped up in my snuggie. I use mine quite a bit for hunting, home utility work, and some night rides. I put mine to use, not just to look like a spaceship in a parking lot. I am not a huge fan of light bars, I think they look pretty stupid; I've taken it off several times but it is a useful piece of equipment.
Time: 15min
Tools:
- Scissors
Materials:
Step 1:
Step 2:
I do not have a light bar, yet. Can you post a wider picture so I can see what bar and lights you are using? The close-ups are great.
Now, how to apply this technology to my mix and match aftermarket mirrors...... hmmm..... (smoke coming out of ears while ponderin' on it.....)
