I have some 0.75" spacers sitting in the bin never used, they're all yours if you want to save the few bucks and that size is worth trying.
Still undecided. I think I want 0.5" and I would like aluminum like what is there now.
I cut up and reassembled my license plate and a new frame. It's smaller with less white acreage.
Before
No more license plate stuff, I promise.
You got new license plates !?
The winch is pretty well hidden with your new setup. I like that.
I was surprised by how easy it was to fix with a press.
Then I improved the thimble keeper and added another small gusset to the extended frame mount.
The filled in Motobilt logo.
A friend of mine bent the fuck out of his drag link a few weeks back; we weren't anywhere near a press, so we used the winch on a rollback and some poor risk-assessment skills to straighten it. As you said; it bent right back into place...after suitable force was applied, of course.
This is interesting. This is a broken body mount bolt from the JKS body lift. Because of the squish, the bolt punched through the tub, making it easy to find. I welded on a nut and removed it from above.
After installing the new nut and lower isolater, I noticed that the hole over the bolt had shifted. Does this mean that the JKS body lift had let the body move to one side? I assume the Savvy puts the body closer to where it should be relative to the frame.
I wonder if that could have been due to install order. Perhaps that side was up high during the introductory tightening causing the misalignment.
