ARB high output on board vs VIAIR 400p
starkey480
Jeep parts inbound
San Tan Valley, AZ
Trying to decide between getting the ARB high output on board compressor that runs for $287 or the VIAIR 400p automatic portable compressor for $247. I will only be filling up tires no lockers or tools. Pros and cons? Would On-Board do anything for me if all I’m doing is filling tires? Arb is 3 cfm and VIAIR is 2.3 at 0 psi.
I don't have an answer to your question, but I have been looking at the Zenith OB2. It's a bit more expensive at $360, but pushes out 4.25 CFM, and has some good reviews. Just another option.
Upon further investigation I would need to get a mount and tire filling kit so the arb would be over $100 more. Probably gonna go VIAIR (especially since I already ordered it haha)
Reactions: Squatch and ac_
ARB hands down. It is designed for this stuff while the Viair is really designed for high pressure applications like air suspension. Those low CFM numbers really matter.
Edit: you can certainly hard mount the compressor for on-board if that's what you mean, if you mean a belt driven compressor that's a whole different ballpark
And to edit again since you already got the Viair, it's great too! It'll get you back on the road.
This is the kit I run. (linked below) But, I modified it so I can plug my air hose in next to the bumper instead of having to open the hood. It fills up a 35" tire from 10psi to 25psi in roughly 2 min each.
I have no experience with the viair system so I can't speak for it.
https://www.amazon.com/dp/B07TXRM272/?tag=wranglerorg-20
Reactions: Sj's TJ
I have (embarrassed to say) the Ryobi 18v air compressor that I use for filling tires. Even wagon and tractor tires. It is small and portable and it seems I only need tire air when away from the shop compressor. It isn't as fast as an onboarding air is, but I can take it anywhere and with any vehicle I want. If the rest of your group is getting annoyed waiting for you to air up, then I would go elsewhere, otherwise it is a great little item. I use their impact, driver, and other items almost daily and they don't let me down.
Reactions: ranger101
I have the Viair 400p and really like it. I’ve never used the ARB so I can’t comment on it. The Viair comes with a nice carrying bag and plenty of line to reach the back corners of the Jeep. I transfer mine between vehicles so it’s not permanently mounted. Picked it up on eBay for $210 a few months back
Just checked, they have it for $170!
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/352001153699
Reactions: FireJeep
I would suggest one with a 100% duty cycle. like the 450.
Awesome glad to hear it serves you well! I already ordered the 400p automatic off amazon yesterday for $247. The automatic model sounds cool because it shuts off between each tire so I don’t have to go back to the unit. I started having a little buyers remorse at first when I discovered the ARB on board because “it’s just $100 more” but there’s always another better one for $100 more with a higher CFM and this isn’t necessarily where I want to put all my Jeep money.
I aired up all 4 tires from 15 to 25psi last week and never shut mine off. The motor was a bit hot but nothing that really concerned me. I went with something that I knew had good reviews and was in my price range. For the handful of times I’ll use it each year, I think it’ll serve me well. If not, time to upgrade!
Dang I didn’t know I could do that. I thought I would have had to turn it off each tire. Could have saved some money there. Oh well 🤷🏼‍♂️
Maybe it’s not advised? Lol I’ll do a little research. I also didn’t waste any time between tires. While ones filling, I go back and install the previous valve stem cap.
I hard mounted a Viair 400H. I have 31.5 inch tires and it airs those up reasonably fast.
I own a 400P portable kit, now a backup and used in other vehicles after I installed a Viair 400H hardmount compressor in my jeep.
See: https://wranglertjforum.com/threads/how-to-simple-onboard-air-for-your-tj-lj-viair-400h.10235/
Two thoughts:
1. The 400 series is a very good value when on sale on Amazon. I purchased mine for about $160. Subscribe to an alert on this website and you will be notified when the item reaches your target price:
www.camelcamelcamel.com
2. The Viair 400 series compressors have a 20% greater output than the 450 series compressors, i.e. they are faster. The 400H puts out 2.30 cfm @ 0 psi and 1.75 cfm @ 40 psi whereas the 450 puts out only 1.80 cfm @ 0 psi and 1.39 cfm @ 40 psi. A 400 series compressor has a 33% duty cycle which means that it is rated by Viair to run for 20 minutes at 100 psi at 72*F ambient temperature before being allowed to cool for 40 minutes. This means that a compressor pushing against only 30-35 psi can run longer than 20 minutes although how much longer is not measured by Viair. Since jeepers seldom inflate a tire to more than 30-35 psi and the 400 series compressor can fill a 35" tire from 15 to 30 psi in 2:40 (+/- 5 sec.) and from 0-30 in 5:05 (+/- 15 sec.) this means that one can fill a set of four completely flat 35" tires before the duty cycle becomes a concern or two sets of aired down 35's. In the 6-7 years I've owned a Viair 400 series compressor I have aired up my own 35's and frequently someone else's 33 or 35" tires in the same session and I have never experienced any issues relating to duty cycle or overheating.
Given the choice between the 400 and 450 series compressors I picked the 400 for its 20% greater cfm rating and after using two of them over 6-7 years I still recommend the 400 over the 450.
